Weird numbness after debracing
Lorianne
#1 Post by Lorianne »
I had my braces removed beginning of August and my ortho did the usual cleaning off of the glue (there wasn't much, I don't think) with that special tool that he asssured me wouldn't damage enamel, but I'm still, 2 mos later, feeling like my front teeth are sort of numb. I'm wearing my retainer nights only and they always ache a bit for a few secs when they first go on, which is normal too I think. I'm worried the drill he used somehow messed me up. Nothing is visible at all though.
Anyone else experience this sensation AFTER braces were taken off?
djspeece
Re: Weird numbness after debracing
#2 Post by djspeece »
I doubt that your ortho damaged you're enamel, but am wondering if your issue is related to slightly shifting teeth. I wore my retainer 24/7 for about 7 months. Perhaps increasing your time per day in retainers would help - but check with your ortho. Also you may want to check the board "the naked tooth, life after braces" if you haven't already (admittedly traffic is lighter though).
Lorianne
#3 Post by Lorianne »
Thank you so much! That sounds very likely that that could be the problem! I'll let ortho know too. Relieved that you don't think enamel was damaged either!
SingleJawMelb
#4 Post by SingleJawMelb »
Dentistry industry is pretty smart when it comes to making applicances that do what they are supported to. I doubt very much the cleaner did anything. If you had issues with hot/cold or pain, I think you would have something to worry about.
However numbness isn't associated with tooth decay etc AFAIK, especially if the patient has braces.
