Anyone else regret their ceramics?
samoorelaw
Re: Anyone else regret their ceramics?
#31 Post by samoorelaw » Mon Aug 22, 2016 11:26 pm
Johnnyboy wrote:Samoorelaw I agree with you. I'm booked in to the orthodontist on Friday to have my top ceramic brackets removed and replaced to the Damon metal the same as I have on the bottom. I wish now that I had had the metal in the first place purely due to the brackets are mush smaller and more comfortable.
Good for you for realizing that. I hope your ceramics come off easier than mine: it wasn't painful, really, just a time-consuming and annoying process. Good luck!
Braces removed for 3rd and final time July 14, 2016!!!!
Permanent 8 crowns front 8 teeth (upper) January 30, 2015
Braces removed again December 3, 2014!!
Partial braces re-installation September 25, 2014
Braces removed September 4, 2014!
Johnnyboy
#32 Post by Johnnyboy » Thu Sep 01, 2016 6:10 am
Hi Samoorelaw, well last Friday I had my appointment for my top ceramic brackets to be replaced with the Damon metal ones the same as I have on the bottom. It took about 45 minutes to remove the brackets and glue and to fit the new metal brackets. She also fitted a thicker arch wire in the top and bottom. Straight away I'm happier with how the new brackets feel. My mouth felt very tight for about 3 days. I wish I'd had these in the first place and I would of saved myself some money too.
alabamaashley
#33 Post by alabamaashley » Thu Sep 01, 2016 9:10 am
I don't have the rubber ligatures; they used tiny wires that you can't even see.
Only thing I don't like is that my orthodontist wouldn't put them on the bottom.
Here's mine:
https://imgur.com/a/uCrzQ
JCloNY
#34 Post by JCloNY » Sat Sep 03, 2016 6:49 am
I have ceramics on top and bottom. To date the only staining I've had is when I downed some delicious curry. I have tea every morning and other "staining" food and drinks without issue. I do however drink my daily tea with a straw.
Zero regrets getting ceramic. It's interesting how many folks think they are invaslign though....
2-year sentence of clear top and bottom braces commencing March 23, 2016
November 2016 - Class III elastics (starts from the bottom canine and goes to the upper 1st molar) on both sides
December 2016 - Two front teeth filed (IPR?) to make space to close black triangle and a power chain; 4 front bottom ceramic brackets replaced with metal brackets to force the teeth straighter; 1 broken bottom molar bracket (courtesy of a Tootsie Roll craving);
samoorelaw
#35 Post by samoorelaw » Sat Sep 03, 2016 3:27 pm
Johnnyboy wrote:Hi Samoorelaw, well last Friday I had my appointment for my top ceramic brackets to be replaced with the Damon metal ones the same as I have on the bottom. It took about 45 minutes to remove the brackets and glue and to fit the new metal brackets. She also fitted a thicker arch wire in the top and bottom. Straight away I'm happier with how the new brackets feel. My mouth felt very tight for about 3 days. I wish I'd had these in the first place and I would of saved myself some money too.
Awesome, glad you're pleased with your decision!
buffon85
#36 Post by buffon85 » Sat Sep 03, 2016 4:56 pm
just live your life. you can't avoid everything. i eat everything i want, i drink coffee, tea, red wine, i eat curry, tomato sauce, mustard and they are just a little yellow. so what? i can't have these two years back, i will keep enjoying everything I want.
one time I ate home made pop corn with red pepper, it was the first time my braces turned neon yellow (two or three days before I ate chicken with a loooot of curry and nothing happened). guess what! I love pop corn with paprika, I won't stop eating it.
after one year and three months, most of the times i don't remember I have braces.
bottom premolars extractions: 9th of June 2015
top premolars extractions: 8th of October 2015
