Black gums three days after getting braces. Is this normal?
Pixelada
#1 Post by Pixelada »
Hi All, I got braces three days ago and everything has been going well so far. I haven't even felt any pain. However, Ijust noticed that my lower gums are turning dark purple underneath my front teeth. Is this normal? Has anyone experience the same? Or should I worry?
Thanks!!!
cdmoses6
Re: Black gums three days after getting braces. Is this normal?
#2 Post by cdmoses6 »
I would definitely get in touch with your ortho or general dentist ASAP. I've not heard of this happening, and could be a serious sign. Don't freak out though, as nobody can tell you what's really going on besides your ortho/dentist :) best wishes to you! I hope everything's okay!
Braces on March 6th, 2015
Metal Empower self-ligating brackets, upper and lower
Class II, Division II overbite with crowding
Upper 2nd premolars extracted May 1st, 2015
First Powerchain and Class II Manatee Elastics June 15th, 2015
TADs placed July 27th, 2015
Box Manatee Elastics April 1st, 2016
Teeth shaping May 4th, 2016
My Progress: http://www.archwired.com/phpbb2/viewtop ... =9&t=48229
Beckett
#3 Post by Beckett »
While I have not experienced this myself, I would say, without trying to panic you, that you should call your ortho as soon as possible and explain what is happening. It could be simple bruising. It could be a circulation issue. It could be any number of things I have no idea about. But it doesn't sound normal enough to let it go.
Braces for 18 months/4 days.
Pixelada
#4 Post by Pixelada »
Hi Guys, thank you for your replies. I think I was just freaking out and now I think is just normal bruising. I have no pain and it has not gotten worse, so I am not going to worry about it. :)
Braces blog/diary: http://pixebraces.tumblr.com
djspeece
#5 Post by djspeece »
I don't think bruising is normal after the application of braces, to be honest. To consider: Are you taking any anticoagulant medications (blood thinners)? I'd be more concerned about an unexpected bleed elsewhere, if you are bruising this easily. As a nurse I'd recommend you contact your orthodontist and/or primary care physician. Best of luck to you.
