Root canal and braces
clairesky
#1 Post by clairesky »
Just wondering if one can get a root canal while they are wearing braces?
oldfart
Re: Root canal and braces
#2 Post by oldfart »
Probably. They would most likely have to remove the wire near the tooth. But I doubt it would be an issue. They can bracket or band the crown when done.
clairesky
#3 Post by clairesky »
why would they have to remove the wire?
boodles8
#4 Post by boodles8 »
I have to get a root canal some time in the next 5 weeks, and my ortho told me the braces would not interfere with it at all. They go through the back of the tooth.
Boodles8
Braced July, 2012
BSSO August, 2013
Debraced October 2, 2014
clairesky
#5 Post by clairesky »
Ever had one before? Do you have molar bands?
boodles8
#6 Post by boodles8 »
Yeah, I had two when I was about 8 or so. I don't remember much about them other than being scared stiff. No, I don't have molar bands, and anyway, the tooth that needs it is a lateral incisor (next to the front ones).
I'm not sure what the picture would look like for bands if you're having a molar done. You should definitely check with your ortho.
Boodles8
Braced July, 2012
BSSO August, 2013
BeautifulDisaster
#7 Post by BeautifulDisaster »
I had a root canal 2.5 months into braces. It was an easy process. I didn't have any wires removed or extra trips to the orthodontist.
27 year old female
Traditional braces: clear uppers, metal lowers
Expected treatment time: 24 months
Brace story: http://www.archwired.com/phpbb2/viewtop ... =9&t=47574
Damian727
#8 Post by Damian727 »
I had root canal done a few weeks ago; orthodontist removed the wire before I had it done, then replaced the wire a week later.
