Powerchain on top front teeth?
SunshineRay
#1 Post by SunshineRay »
Have you had one? If so, how long was it on? I got one yesterday and I feel like it has a spotlight on it.....drawing so much attention to it. Just as I was getting semi comfy with the braces and now its like BAM! I feel the pressure, the gap wasnt that big to start with and I can honestly notice a difference already. Just curious on how others treatment went.
jem
Re: Powerchain on top front teeth?
#2 Post by jem »
Hi Sunshine Ray,
I had a powerchain to close a gap ( created by IPR) between my two front teeth. The gap was closed within 48 hours, but I kept the powerchain for the 6 weeks up to my next appointment. That left me with a gap between my right lateral and central when I needed space on the other side, so my ortho then placed a powerchain on both central teeth and my right lateral for the next 6 weeks, which moved the gap over to the left where it was needed to help slot my left lateral back into line. My ortho then put a holding wire ( other people call it " lacing") onto the same 3 teeth to stop any gaps opening up between them. I kept that wire for the next 7 months or so until it disintegrated.
I felt quite strong pressure from each powerchain for the first couple of days, but they were ok after that. They were both clear elastic and virtually invisible and I took care to avoid eating or drinking anything which might stain them, although I did have a curry a couple of days before my ortho appointment and the chain looked gross.
Good luck with your powerchain; it is just another part of the orthodontic process which you will soon get accustomed to.
Jem
nellarmonia
#3 Post by nellarmonia »
What color do you have? I've had a powerchain on my entire top arch for the past 4 months (changed 3 times). It's smoke colored and I think it's more invisible than the smoke ligs. It does stain A LOT easier though. I everything messy with a fork and shove it to the back until the last week before an adjustment.
Good luck with your powerchain! Pressure just means it's working right? :D
JohnsonSon
#4 Post by JohnsonSon »
As my top teeth were pulling out some gaps started to form around my 6/7's and my first molars.
So for the past 3-4 months or so, I don't remember exactly, I've had powerchains on top. I don't feel it all. I do notice my teeth getting tighter when I floss though, so maybe it will come off soon, who knows.
TMJJill
#5 Post by TMJJill »
I'd say that the length of time in powerchains really does vary from person to person.
I had them through much of my treatment. After those early days when there is a ton of movement with them, they do get much more comfortable.
I wasn't actually given a choice of color for my first series of chains. They just automatically gave me clear. The clear does get a bet discolored over time, but it was never too bad. I actually wanted to have fun with my chains. I had to ask for colors. I loved the navy ones. For me, pink not so much.
I can't remember exactly, but I think my top power chains were about 11 months of my treatment... on and off. The bottoms were just for a few months.
The thing I most disliked about the powerchains was the flossing. Flossing with the braces is tough enough. Working around the powerchains was just a pain.
Hang in there. :-1 The pain will get better. Try to have fun with the chains. You notice them much more than anyone else, just keep that in mind.
Removal of Braces: September 18, 2013
TMJD treatment now complete!
fudge911
#6 Post by fudge911 »
Currently have two powerchains on each arch to close my extraction gaps. I've only had them on for about 2 weeks and already I see a massive improvement in the closure of the gaps, especially the top arch. It's incredible. The first couple of days were a pain, literally, but as of now, they haven't been much of an issue.
