Avoiding Flossing
Winkos
Avoiding Flossing
#1 Post by Winkos » Mon May 27, 2013 9:50 pm
I should have gone to bed a half hour ago, but I am so avoiding the 20 minute floss that I am still awake, reading this forum. Does it get faster and easier with time? I have worn metal braces for 11 days and can't seem to cut the time down. The pesky molars are hard to get to, my cheeks keep getting in the way.
Chicken
Re: Avoiding Flossing
#2 Post by Chicken » Mon May 27, 2013 10:06 pm
It does get faster. I invested in a waterpik which I use prior to flossing before bed. I also use it after each meal it really helps get the food out.
Tobilei
#3 Post by Tobilei » Mon May 27, 2013 10:13 pm
10 minutes is about as quick as I've managed to get. I did get quicker temporarily, then they bracketed my back molar and added looped small powerchains across the top back 4 teeth on each side and I had to start from scratch. You do get quicker but never as quick as you were prior to being braced :(
agrace90
#4 Post by agrace90 » Mon May 27, 2013 10:46 pm
I just finished flossing and was so frustrated I turned here for some light too! Your definitely not alone. I've been braced for a week now and am starting to feel my teeth moving. They are so tight! They were before but now I can't even get floss between them, and when I do it shreads on the way out...so frustrating. I just had a deep cleaning before braces and don't want it to go to waste. Hopefully it's not too bad to miss a few teeth until they loosen up.
OldBikerBag
#5 Post by OldBikerBag » Tue May 28, 2013 12:17 am
I cheat: I use the tiniest proxy brushes I can find and shove them between my teeth at the gum line. They're the green GUM Go Betweens. I get them at WalMart. After the little brushes, I brush with hydrogen peroxide about two to three times per week.
With my arthritis, it's impossible for me to keep hold of the end of the floss that isn't attached to the threader. The ortho and his assistants are always complimenting me on how clean I keep everything, so it must be working.
385 Days in Damon Braces
Ciara
#6 Post by Ciara » Tue May 28, 2013 12:31 am
It does get faster. I was doing really well until my ortho put bands on 2 molars. Now it takes forever to floss. And some days I really love my Waterpik
Leebie3
#7 Post by Leebie3 » Tue May 28, 2013 2:24 am
Me too oldbikerbag!!
38yr old Mum to 3 (2 teens and a preppie) living in paradise with her man. BSSO surgery approx late April 2014!
djspeece
#8 Post by djspeece » Tue May 28, 2013 4:22 am
I do a modified oldbikerbag routine (MOR); I use the interdental brushes dipped in the purple Listerine stuff after first blast the braces and gumline with the waterpik. Then I rinse the rest of the purple Listerine in my mouth vigorously for what seems to be an eternity, and hten comes brushing with an OralB and the flossing tip, then rinse with a peroxide product (Crest makes it), then a flouride rinse, and then finally I am done. Oh and I have one of those tongue scrapers too. The hygienists are pleased with the result and they are a hard group to impress.
beckyboo0205
#9 Post by beckyboo0205 » Tue May 28, 2013 1:25 pm
I was pretty slow at first then I got good and fast at it. THEN they connected my wire to my very back brackets and it's a little harder now. Those last ones are hard to get!
plugnickel69
#10 Post by plugnickel69 » Tue May 28, 2013 7:12 pm
FlossFish. Takes 3 minutes!
xanidu2012
#11 Post by xanidu2012 » Tue May 28, 2013 9:04 pm
Time wise I've gotten faster. Molars are another problem. I try as best I can but trying to get cheeks out the way is a pain in the butt. Some times I just leave and try to rinse as best I can.
Sita
#12 Post by Sita » Wed May 29, 2013 9:32 pm
I can do mine in about five minutes with Oral-B superfloss. It just takes practice. :-)
altesse7
#13 Post by altesse7 » Fri May 31, 2013 5:30 am
The first week took me maybe 1/2 an hour. I used the Superfloss, the othro gave me. But, I found it breaking and spreading. So, I got Glide brand Superflossers, that come individually packed. The threaders is so much better, it works 10 times better on banded teeth (it won't break), it just much studier.
Flossing takes me, 10 muni metes, now. I floss molars,last.
May 6,2013- Traditional Braces applied
To upper and lower
Length of treatment- 18-24 months
No more Elastics, as of 10/20/14
Horse Lover
Winkos
#14 Post by Winkos » Sat Jun 01, 2013 6:03 am
I want to use those little brushes like many of you do for the molars as I can use those quickly, but the orthodontist said "absolutely not, use floss". Are those little brushes just as good as floss? I could cut flossing time in half if I used them. I am going to try the Glide superfloss next as suggested.
Sita
#15 Post by Sita » Sat Jun 01, 2013 10:10 am
Winkos wrote: Are those little brushes just as good as floss?
In my experience, no. I used them only for a time earlier this year and found that my gums became irritated after a few weeks as they usually do when I don't floss. So I went back to flossing every day and it all cleared up.
