And Then What?
JillD
And Then What?
#1 Post by JillD »
I had four premolar (and three wisdom tooth) extractions for my overjet problems. I just passed sixteen month (and one week) mark. The extraction gaps that looked like as if they would never close are getting closed nicely, leaving less than one millimeter only on one gap. I think even this gap will close before my next appointment. Because it was the humongous gaps that bothered me the most during the process so far, I feel as if I should be done soon. But I know that wouldn't be the case. My ortho quoted two year treatment (and two other orthos I saw for a consultation quoted two and a half year). So now I wonder what I would be waiting for once all of my gaps completely close. My DH says I will wait for my teeth to be stabilized. If true, how long would it take?
amyhenna
Re: And Then What?
#2 Post by amyhenna »
I've been wondering kind of the same thing. I just had my first adjustment yesterday, just two weeks after getting only the bottoms put on, and already my two bottom front bottom teeth are uncrossed! Don't get me wrong, I'm NOT complaining :-* but I am trying to figure out if things move at this pace, how is this going to take 18-24 months?? Maybe it's to do with adjusting the bite. Maybe that takes longer.
emoticon1234
Re: And Then What?
#3 Post by emoticon1234 »
From what I understand, adjusting the bite is what takes the longest. Getting the teeth straight only takes about a year or so, depending on treatment, etc. Mine are fairly straight at the 14 month mark but I still have two gaps. The one between my top right canine and premolar got closed by the box elastics, and we can't even start closing my left top because the tooth still hasn't descended... Bottom right was getting closed by a power chain but has since moved back when they stopped using them (after I kept shredding them between adjustments). Bottom left doesn't have a gap because that's where all the crowding was.
amyhenna
Re: And Then What?
#4 Post by amyhenna »
What's this about descending teeth? I just heard of it today in your post and another. Is it common for orthodontics to pull out teeth up/down to make them taller?
emoticon1234
Re: And Then What?
#5 Post by emoticon1234 »
One of my cuspids hasn't dropped down, and when I had my oral surgery to take 8 of my other teeth out, they cut my gum and attached a gold chain and bracket to the unerupted tooth. they sewed it back up and for the past year they've been trying to gradually bring the tooth down with a spring. When I was younger I had some problems and they had to take out my baby canines and three other teeth to make room for the adult ones. Unfortunately, my adult canine never had the room to come down so it's still stuck up in my gum... So I guess when I say it hasn't descended I mean it's not even showing enough to have a bracket on it yet.
