Who applied your braces?
I'm just curious to know what's more common. Did your orthodontist apply your braces, or an assistant?
- BracesChick
Re: Who applied your braces?
Assistant. I was a little shocked about this.
I also had an assistant put on my braces. After she was done, the Ortho checked them.
Female, 25
January 21st, 2013: Spacers Placed
January 26th, 2013: Porcelain Uppers with White Wire and Metal Lowers with Metal Wire
Sentence: 24 Months
Assistant prepare teeth and add glue, then ortho applied braces he also set up wire and then assistant do ligatures at the end he checked.
I'm debraced after 2 rears and 1 weak of treatment.
Mylovedtheeth wrote:Assistant prepare teeth and add glue, then ortho applied braces he also set up wire and then assistant do ligatures at the end he checked.
Same with mine. Except the ortho put on the glue too...
His assistant. But he checked everything before she used the blue light to cure the glue.
Life is not measured by the number of breaths you take,
but by the moments that take your breath away.
-- Maya Angelou
My story here: [url]http://www.archwired.com/phpbb2/viewtopic.php?t=42752
and here:
http://www.archwired.com/phpbb2/viewtop ... =9&t=42976
My blog: http://dvorahstraintracksadventure.blogspot.ca/
-- Maya Angelou
and here:
Same here. Ortho did the brackets and glue stuff and assitant added the wire. I am still surprised to this day how little contact I have with the ortho. I see her somewhat regularly but usually for about 5-10 mins max.junglejulie wrote:Mylovedtheeth wrote:Assistant prepare teeth and add glue, then ortho applied braces he also set up wire and then assistant do ligatures at the end he checked.
Total sentence 567 days.
Debond day: Dec 10, 2013
That's strange but I know all orthodontic practices are different. I've see mine every time I've gone in so far. But he does seem to have a lot of assistants working in his practice. About 7 or 8, it seems.
-- Maya Angelou
and here:
-- Maya Angelou
and here:
My ortho does almost everything. She cleans, brushes, applies etching, glue, places bracket, wire and metal ties etc. The assistant passes things to her, takes impressions, and removed my wire at my first and second adjustment. At my last adjustment, my ortho did everything, even giving me the anesthetic before my dentist came and replaced a temporary filling.
My orthodontist does the glue and brackets. The assistants put the wires in, adjust the stoppers, put extra hooks on and take tons of pictures.
When I go in for 'fixes' in between ortho visits, the assistants usually take care of me. I see the orthodontist about 1/3 of the time on the 'in between' visits.
My ortho does pretty much everything. The assistant hands him the ligs and tools etc or holds the suction if need be but he does everything else. She did the drying when my brackets were placed and handed those to him, but he put them all on. He does all my adjustments also.
Assistant preps the teeth and puts glue on the brackets. Ortho places the brackets and does a quick light cure. Assistant finishes up with more light cure, wire placing, power chains, bends, hooks, lacing. At my last visit, my ortho did everything. Mine will be this way from here on out. In fact, they made sure to book more doctor time for me next time.
They know I ask a lot of questions, so I guess he makes sure he addresses my concerns.
Orthodontist did everything the first appointment when they were put on. The assistant did the whole cleaning demonstration etc but that was it. First adjustment the orthodontist had a look first, assistant changed wires and o rings and then orthodontist came back to check everything and talk about what he's planning for the next visit.
It was an assistant that placed all my brackets. The ortho came over and carefully checked the placement of each one. Then he gave the ok for the blue light to cure the glue.
For my adjustments, an assistant removes the ligs, and the ortho checks my progress and lets her know what needs to be done.
