Is it possible to do damage to the metal brackets themselves?
under normal brushing and eating conditions
I read somewhere that brackets can get scratched bad enough to need replaced...
Scratching Brackets
Re: Scratching Brackets
I'm sure if you try hard enough you could scratch a bracket, but stainless steel is pretty hard and I think it would take more than normal brushing/wear to damage them to the point where they need replacing.
Elizabeth
Getting top and bottom traditional metal braces and bite turbos
correcting crowding, overbite, and TMJ on 3/6/2012
Turbos Removed 8/14/2012
Click for my story
Click for my story
Unless you're eating diamonds and metal rods, I think you're fine
Just try to keep from foods that would damage them (nuts and similar stuff). Take care of them and you'll be OK. I haven't heard about brackets that get so scratched they can't be used anymore, but they can get off your teeth and that means a trip to the orthodontist. That's why you're advised to eat stuff that won't break the 'cement' the doctor used to stick them to your teeth
Orthodontics patient from 2007 to 2010.
Orthodontic Braces
Orthodontic Braces
Thanks, I'd never heard anyone say it before.
I've been doing a lot of reading...I know anyone can put anything on the net.
I knew I'd get the right answer here.
