Thanks for your reply Kipepeo.
Kipepeo wrote:Also, you appear to have an open bite, but maybe you are just not biting all the way closed in your first photo. If you are closed, then to me it appears your bottom canine teeth hit pretty prominently on your uppers.
My bite is slightly open but not as much as appears in that photo which is a bit misleading, eg it does look like my lower canines hit upper on the RHS of the photo but this is not the case (Note to self take a photo with proper bite showing next time
Kipepeo wrote:So question to you - Why do you have just bottom braces? What were you trying to accomplish from the braces in the first place?
I had a gap which had opened up from removal of lower central incisor from first time in braces so just wanted the gap closed, I wasn't very fussy, just wanted the gap closed which was quite wide as you can see in this before photo.
But now that the gap is closed the overjet is quite apparent particularly on the side that I have queried in my after photos in the first picture on this thread. So I am just thinking to do some final work on that would be worth it before wrapping up proceedings.
Kipepeo wrote:So, long and short, yes your ortho can bend your wire to fine tune tooth placement. I'll advise you that it may take some time with multiple adjustments to get where you want to go.
Thanks for that just the kind of info that I needed.
I would welcome further comments and opinions, thanks guys
