Loose Tooth
Loose Tooth
Hi Everyone
I would just like to know if this is normal. I have one tooth at the top which is quite loose, if I press on it i can see it moving in the gum.
I know teeth go through a process of being loose and tightening up on and off with braces, but this seems different.
The tooth in particular is constantly being knocked by the tooth below it, and i clench my jaw when i sleep so it gets a lot of pressure as well.
I mentioned this tooth to the ortho, but he said its fine theyre all loose!
Any thoughts?
Any thoughts?
Re: Loose Tooth
WEll your ortho would know best.
But i have a tooth that feels more loose that the others too...Asked my ortho and he said basically the same thing.
I guess we all get kinda paranoid with braces huh...im always checking to make sure nothing isnt broken and stuff.
FINALLY Me after braces : http://www.archwired.com/phpbb2/viewtop ... 13&t=46650[/color]
Re: Loose Tooth
I'm also getting paranoid because of some teeth that feel losse at the moment ,,
I don't know if this is normal or how long it would take to settle again
Basically they are 2 loose tooth which has moved a lot during the past months and my ortho gave me elastics to be put on this loose tooth I'm so scared .
I hope some one who were in the same situation can calm us down
Quad Helix Expander and Braces to correct unilateral posterioor crossbite (TMJ treatment ). 6 months
Braces journey : 11 months 3 weeks (from 12 march 2012 to 3 march 2013)
My Story and Progress Update
Re: Loose Tooth
It is normal to have loose teeth.
Even to have one feel looser than the others.
It takes time for everything to calm down.
Just remember that loose teeth are a good thing because it means you are having movement.
Metal brackets & 4 bands on May 12, 2011
4 Premolars Extracted on May 20, 2011
Fully braced on May 25, 2011
My sentence - 24 to 30 months
My Story: http://www.archwired.com/phpbb2/viewtop ... =9&t=39348
Re: Loose Tooth
thanks...i wasnt too worried...i figured the ortho knows what he's talking about...and he didnt look bothered when he examined it so yeah...
Wish i could SEE all the "movement" that is supposedly happening
Re: Loose Tooth
nikkibabie19 wrote:thanks...i wasnt too worried...i figured the ortho knows what he's talking about...and he didnt look bothered when he examined it so yeah...
The bond has to be "soften" and then the teeth can move.
Take pictures, it helps. I take pictures every month and it helped me a lot in the beginning. It makes you feel so good about your decision.
Re: Loose Tooth
Where is that doggone "Like" button?!?TinkB wrote:nikkibabie19 wrote:thanks...i wasnt too worried...i figured the ortho knows what he's talking about...and he didnt look bothered when he examined it so yeah...
We get a tattletale button, but no "Like" button....
Oh, well.
+10, TinkB
385 Days in Damon Braces
Re: Loose Tooth
Thanks for the reassurance everyone, I'm feeling a lot better now
If we're all in the same boat (the loose-tooth boat lol) then I guess it must mean what we're going through is normal and knowing that we're going through it together is a great comfort. Phew!
I'm meant to be having my teeth cleaned today and my first filling (eeeeeK!!!!!) I'm stressing about the filling but even more about the cleaning. My teeth are so loose im worried they may come out when he presses on them
Does anyone know if its a good idea to have my teeth cleaned a week after an adjustment?
xxx
xxx
Re: Loose Tooth
i do take pics...but i think its too soon to see any movement. lol
I have only had braces for 13days.I think im jus anxious to see change esp readying and seeing so may pics on here of progress in 1mnth and stuff...
Oh well i'll keep taking pics....maybe after a good month i;ll watch day 1 pics and compare it to day 30pics
Bcuz right now i keep comparing day one with day 5pics...
