they've been on since Nov 28 and my mouth hurts DAILY
Mnamom1105
#1 Post by Mnamom1105 »
Ok, so I knew braces would hurt in the beginning. I knew they would hurt after adjustments. but I did not expect it to hurt constantly. Two tylenol and 4 advil twice a day to take the edge off. I've mentioned the pain to my orthodontists, and they say that I am the odd ball - they've never had anyone with these problems.
Most days it hurt to put pressure on my teeth with toothbrush and brush them. I have been unable to bite ANY food - even soft bread. Chewing is also equally difficult/impossible some days. I cut food in bites for me as small as the bites for my 1 year old.
Any suggestions? could I just be sensitive to the pain (more so than most people)? Am I an odd ball? My dentist says he does not think this is normal....
NickelNikki
Re: they've been on since Nov 28 and my mouth hurts DAILY
#2 Post by NickelNikki »
If it's causing you that much pain and problems eating then perhaps you should stop. Your health is the most important thing.
I had Inman Aligners on both my top and bottom teeth.
View my progress here: http://www.archwired.com/phpbb2/viewtop ... =9&t=41962
badbites
#3 Post by badbites »
Sorry to hear of your continual troubles...must be very miserable.:( I can't imagine the aching I've had in the last two days being continual...would be very demoralizing.
Did your ortho tell you what size wire he's using on you? I just got my first wire a few days ago and my ortho told me they always start with the 0.014 wire with new patients and typically maintain it for 3-4 months to allow patients to adapt before putting a stronger wire in. Maybe request the thinner wire (if it's not being used already) to see if that helps.;)
