Makeup anyone?
Makeup anyone?
So I have the clear/tooth colored brackets on top and I discovered this morning that lipstick may not be the best idea...I had a bunch of pink stuck in them.
Am I doomed for the next year? Or are they're any suggestions for lip colors that won't rub off on them! Thanks!
Re: Makeup anyone?
I'm not a huge lipstick fan to begin with, usually a it of gloss when I'm going out with the girls but I haven't put any on at all since braces. Just lip balm because my lips get so dry and flaky. Yuck.
ST
ST
Re: Makeup anyone?
I also just use lipgloss or chapstick instead of lipstick. Since getting braces I have just stayed away from the lipstick. If you really love your lipstick, perhaps try a colorstay type so once it's on it won't smudge onto the teeth? I think Revlon ColorStay is a great one...hopefully I have the right brand, hehe, it's been a while!
Re: Makeup anyone?
I wear lipstick, but no problems with it on my teeth or braces.
Ceramic braces top & bottom on 6/24/10
Re: Makeup anyone?
I use lip gloss - bare minerals (come in all shades, just like lipstick) - also stops my lips drying out too much which then causes braces to rub as my mouth gets dry!
Re: Makeup anyone?
I had the same problem. So my lipsticks & darker colored lip glosses are in my closet for now :( In the meantime I'm using up my clear and light pink lip glosses and of course chapstick.
Re: Makeup anyone?
The Covergirl lipstain...can't remember what its called. It's like a felt pen. I use it, then put on my Blistex. Love it. They have a lot of shades too. Try it out.
Re: Makeup anyone?
Before braces I was a fan of bright pink lipstick, but now I find it really emphasises my braces and like you said, gets stuck in them.
Now I am into light colored lipsticks at the moment. I'm especially loving MAC lipstick in Lovelorn. It's a nice light pink color.
After I apply lipstick I blot a bit of it off so I guess it's kind of just like a stain and not all gooey. That helps it not get in the braces.
Re: Makeup anyone?
I never wear lipstick because I don't like the feeling of anything on my lips (I just end up licking it off accidentally ) so I don't know about it getting stuck on braces, but as "ashesgap" suggests, you can use a stain. A stain is near impossible to get to rub off on anything once it's dried.. it just sort of goes on your lips like ink and leaves the colour behind.
It's the only kind of lip-colour I feel happy with, braces or not!
Re: Makeup anyone?
Good suggestions! I never thought of a lip stain before...but you see them all over the place now. I'll have to go pick one up!
Re: Makeup anyone?
Good Question.
I could never really wear lipstick before because it would rub off on my upper teeth. I am looking forward to buying a new lipstick for my debrace day but for now might look into the lip stain idea too.
34 years old, 2nd timer, Original sentence 2.5 years - Updated to about 20 months
Braced December 16th , 2010
Debrace Date August 22, 2012
My story http://www.archwired.com/phpbb2/viewtop ... =9&t=37941
Re: Makeup anyone?
I love lipstick but it just doesn't look right on me with braces. It looks like I am a child playing dress up. It's all over the teeth and just not hot.
www.allbraced.blogspot.com
- BraceFace2o1o
Re: Makeup anyone?
I would recommend a lip stain too. I tried my first one a couple of months ago and really like how it doesn't end up on my teeth!
I have metal braces so lipstick on them wouldn't show as much as with ceramic braces, but I still hate it when lipstick gets on the actual teeth... someone always manages to say something like "ohhh what is that on your teeth?" erm lemme check, oh, lipstick! thanks for telling me, no seriously.
Re: Makeup anyone?
okay, I tried a lip stain and it still DIDN't work! It looked good for the first few minutes..then I went back and checked in the mirror about 10 minda later and my cermics had a nice pink hue to them...lip stain FAIL
I guess I'm banished to the world of clear lip gloss for a while
Re: Makeup anyone?
Did you blot it off? I leave it for a minute or two.. then blot off any liquid with tissue.
