Unsatisfied with my orthodontist's work. What should I do?
JohnDoe
#1 Post by JohnDoe » Thu Nov 18, 2010 10:56 pm
I wore braces for a year. After the braces came off my orthodontist had me on Invisalign retainers for 5 months. I wore them every day and removed them only to eat and brush my teeth. The problem is that to this day my teeth have not stabilized. Not only that, but they have shifted and new gaps have formed between them, even though I have worn the retainers as indicated. My orthodontist blamed the failure to keep my teeth in place on subconscious bad habits on my part. I don't know if that's true, since the supposed bad habits are subconscious, but the treatment has lasted far longer than promised and the result so far is unsatisfactory.
What are my options?
bbsadmin
#2 Post by bbsadmin » Thu Nov 18, 2010 11:45 pm
Perhaps you should try a Hawley retainer instead. It can be tweaked to help move your teeth slightly to eliminate the gaps you mention.
Also, I'm surprised that your orthodontist said to only wear the Essix retainers (which is what they are properly called) for five months. It can take much longer for the periodontal ligaments to stabilize, depending on what was corrected in your treatment.
JohnDoe
#3 Post by JohnDoe » Thu Nov 18, 2010 11:50 pm
bbsadmin wrote: Also, I'm surprised that your orthodontist said to only wear the Essix retainers (which is what they are properly called) for five months. It can take much longer for the periodontal ligaments to stabilize, depending on what was corrected in your treatment.
Five months 24x7. Then only at night.
But I still must wear them 24x7 because if I wear them only at night the teeth shift significantly.
dangerdude
#4 Post by dangerdude » Fri Nov 19, 2010 9:55 am
You could always sue him in small claims court.
But didn't the ortho already do his job? He made your teeth straight? I think that's how a judge would decide.
JohnDoe
#5 Post by JohnDoe » Fri Nov 19, 2010 10:41 pm
dangerdude wrote: But didn't the ortho already do his job? He made your teeth straight? I think that's how a judge would decide.
I don't know how a judge would decide such a case, but when people pay to have their teeth straightened it's probably because they are looking for something that will last longer than a few months.
I'm also not sure the treatment is done yet.... The orthodondist had me come back to his office for a follow up for a reason.
