loose teeth
wired nana
loose teeth
#1 Post by wired nana »
I just got my braces on two weeks ago and have a couple of loose teeth. I guess the teeth have to loosen up in order to move, but it's kind of freaking me out! Is this normal?
Snowglobe32
#2 Post by Snowglobe32 »
It is normal. Kinda cool if you ask me. :D
b
#3 Post by b »
Totally normal!
Its all part of the fun. Just dont wiggle them a bunch on purpose, or they will probably get sore!
Spacers in Aug. '09
MARA without elbows on Aug/09
Braces on Nov. 20/09
Elbows for MARA in Feb. 25/10
Braces off August 26, 2010!
Essix Retainers
my story: http://archwired.com/phpbb2/viewtopic.php?t=33571
jambo532
#4 Post by jambo532 »
yup totally normal. Random teeth with just get loose then go back to normal... it's weird when you go for an adjustment and they take your wire off for the first time then your teeth really feel loose.
www.allbraced.blogspot.com
wired nana
#5 Post by wired nana »
Thanks everyone. I'm glad to know it's normal, but it still feels weird!
hal2me
#6 Post by hal2me »
Hi wired nana,
I agree; it does feel wierd! If I clench my teeth in the mirror, I can see them move. It is normal, but odd at the same time. This time, you don't want the teeth to fall out in order to get some money from the Tooth Fairy :lol:
Best of luck to you!
wired nana
#7 Post by wired nana »
I'm happy to say that my loose teeth have moved slightly and have tightened back up. I have had my braces for one month now, so that's pretty exciting! I had this big fear that since I'm a middle aged woman with low bone density that my teeth wouldn't tighten up again. I had visions of them falling right out. Yea, I'm so happy!!
LC'sTeefs
#8 Post by LC'sTeefs »
OMG...when my teeth first started moving, and getting loose all over the place...I had nightmares that my teeth were falling out! I woke up one night in a sweat, and had to go check my teeth in the mirror to make sure I hadn't lost any. :oops: I'm better now about not stressing over teeth stuff, and usually in about 3 days the problem is gone and moved onto another tooth.
