OH MY GOD
OH MY GOD
My son banged his head against my mouth yesterday on the upper left side where I have my braces points. Now my mouth is swollen very badly. I know my teeth are okay. Its my skin inside the mouth which is hurt badly and makes my mouth swollen.
Should I go to Orthodontist? The only problem is she is too far & I don't feel like going unless I have to go.
What are the options I can do? I took 2 pain killers today & I feel little better. Any more suggestions?
call your doc and ask his/her opinion.
Developer of:
http://sixmonthbraces.com/
why does everyone think it as allways about money?
In most offices where you are getting braces that is a freebe anyway.
Put ice on your lip (off and on) and put some wax on your brackets.
Developer of:
- TumbleDryLow
Honestly, if you think that your teeth are OK and there is no damage to any brackets, there is very little your orthodontist can do for you. The tissue inside your mouth just needs time to to heal. Cold compresses and Advil for the swelling, salt water rinses and wax to help with the abrasion are about all you can do. I'm sure you will be fine in a week or so.
Ditto what everyone here said. I used to laugh and "pooh-pooh" my dentist when he told me to rinse with salt water to alleviate the gum pain I had after cleanings. Those rinses are a lifesaver to me now! They are so soothing. I also tried to be brave and go without the wax, but you just cannot. You won't have to wear it forever - just until the area that's being irritated toughens up a bit. For me, that was a day, max.
Hang in there!!
Hang in there!!
You were right. I took pain killers and waited for a week. Back to Normal again. Thanks!!TumbleDryLow wrote:Honestly, if you think that your teeth are OK and there is no damage to any brackets, there is very little your orthodontist can do for you. The tissue inside your mouth just needs time to to heal. Cold compresses and Advil for the swelling, salt water rinses and wax to help with the abrasion are about all you can do. I'm sure you will be fine in a week or so.
