Elastics question
Elastics question
I just got elastics on friday (for the record... mountain gorillas). This is kind of a silly question... when you take out your elastics to eat, where do you put them? I had thought of putting them in my pocket but they might get fuzzy (ewww) or I might have something in my pocket- like coins (ewww). They said to change them twice a day- which doesn't quite coincide with 3 meals a day. It's okay if I'm home, but if I'm at work or at the mall or a restaurant, where should I put them?
04/09/09- Consult, 04/21/09- Spacers in, 04/23/09- Braces on, 06/01/09- Extractions
06/25/09- First Adjustment (new wire, but same size- all the way to bck molars- after extractions)
08/20/09- Second adjustment (same size wire but got Powerchains top and bottom!!!)
10/02/09- 3rd adj (same size wire, new powerchain, started elastics)
12/10/09- 4th adj. (same size wire, new powerchain, same elastics)
02/11/10- 5th adj.
02/11/10- 5th adj.
wrap them around your finger
Developer of:
http://sixmonthbraces.com/
Yes, I agree with Lela - drop them in the trash.
I wear mine 24-hours per day and I never reuse them. You'll find when you put a fresh set in they are tighter, so I think they lose their elasticity quickly. I change mine in the morning and every time I brush during the day (after meals, basically).
clear Radiance brackets top and bottom
In my napkin. Then the trash.
Then I put new ones in.
If I run out, my ortho will drop me new ones in the mail or I can drop in at her office and get a couple of packs and a great hot chocolate.
Mike
Mike
But who's counting?
Jaw Surgery June 1, 2009
But who's counting?
The easiest thing to do is just replace them each time you have to take them out. Often I try to keep them in to snack so I don't use more than 3 sets a day, in certain cases I use a napkin but mostly just throw them away and use a new set. You'll feel the tightness, I love that feeling!
braced 07/02/08, braces off january 2010
sentence: 18 months, upper and lower damons + elastics
Bonded+essix retainers
My story: http://www.archwired.com/phpbb2/viewtopic.php?t=28298
I am supposed to keep mine in when I eat (which is easier said than done). I do usually try and do it unless I am eating in front of people who might find it a little gross. But I do change tehm when I brush after every meal. I do notice the new ones are tighter and feel like it might help speed things along.
KimC
KimC
A good solution to carrying them is to put them in a half filled wax container. I normally can put ten elastics (enough for a couple of days) and have wax available in case I need the wax. I will need he elastics.
Mike
Mike
But who's counting?
But who's counting?
thanks everyone... I'll just change them after meals and call for more when I run out.
T
T
02/11/10- 5th adj.
02/11/10- 5th adj.
