Rotating Teeth
Megan11
Rotating Teeth
#1 Post by Megan11 » Sat Dec 20, 2008 1:32 pm
Generally speaking, how do ortho's rotate teeth? What tools/techniques are used to get the tooth rotated to its proper position?
And do you need to go the tooth aligned first, before you rotate it?
Damon 3's
First 6 Clear/Metal
lionfish
#2 Post by lionfish » Sat Dec 20, 2008 1:35 pm
My ortho used a powerchain to rotate one of my premolars, which wasn't aligned at the time.
Maverick
#3 Post by Maverick » Sat Dec 20, 2008 3:45 pm
Tooth rotation can start with just Elastic Ligatures on the wire.
Powerchains can also be used to rotate and ligature placement can be used (Lig on only one half of the bracket).
Soworththeeffort
#4 Post by Soworththeeffort » Sat Dec 20, 2008 5:49 pm
In addition to powerchains (attached horizontally to the archwire), and elastics (attached in many, many different configurations to brackets), your orthodontist may also crimp your archwire to rotate a tooth. (I'm not sure what the criteria is for using elastics and/or powerchains versus crimping the archwire - my orthodontist has used all three different techniques to rotate the same tooth....maybe they just keep trying different ones until one works?) Hope this helps.
Megan11
#5 Post by Megan11 » Sun Dec 21, 2008 9:33 am
I see now, thanks for the replies. I was under the impression that power chains were strictly for closing gaps...I guess I learn something new everyday ha.
Damon 3's
First 6 Clear/Metal
sdawdy
rotate teeth
#6 Post by sdawdy » Mon Jan 19, 2009 12:40 pm
Because my teeth are so freaking stubborn, my ortho tried
Springs
Power chains
and finally, had a rubberband from the back of the tooth to the front of the tooth on the top....really weird feeling at first....
funshine
#7 Post by funshine » Tue Jan 20, 2009 8:01 pm
I had a really badly rotated tooth. My ortho used a button for a couple of months and then moved to a regular bracket. It turned around first and then moved into place.
