Hi,
I went to see an ortho and decided to get braces. He was booked out for months so he said that the other ortho in the clinic can put braces on earlier. I agreed and got my apointment sooner and got my braces put on 6 days ago.
I was just reading a letter the ortho sent me earlier and it mentioned that molds would be taken of my teeth, but the other ortho never took molds! Is it unusual that no molds were taken and will this cause an issue down the line !?
My teeth are quite crowded and I'm supposed to get either have 4 teeth removed or get anchor plates put in later. I questioned the ortho about the mold and he said it dosn't matter he has pictures, but the picture are just side shots of my teeth.
Should I be worried ??
Very worried, mold wasn't taken
- married2abuckeye
I wouldn't worry. My Ortho never took molds of my teeth either until the very end of my treatment (when they were needed to make the retainers). My ortho would refer to my photos and x-rays during our visits. I think that molds probably aren't necessary in all cases - even if you think your case is complicated, it may not require the use of 3D models.
Good Luck!
Good Luck!
Don't Worry
Hey! I didn't have molds taken of my teeth, either. Instead my ortho took polaroids and x-rays. Everything seems to be working fine for me and I've had mine since February.
- GiovanntiLawing
Hi,
Nowadays, molds aren't really used too much these days. It just depends on the ortho. At least thats what my ortho told me. I've used the same ortho twice. 11 years ago, and this year. He used molds the first time, and this time around he did not. I guess, since technology has advanced, some ortho's use diff methods to determine your treatment.
I'm sure you're ortho knows what he is doing...Good luck with your treatment though
Giovannti. 26 years old with braces..
http://bracesandthecity.blogspot.com/
2nd Time w/Braces
Metal-First time 10 years ago
Ceramic-(Second time) Top Arch Installed 7/9/2008, Bottom Arch Installed 9/10/2008
Next Adjustment 11/25/2008
Word of advice: WEAR YOUR RETAINERS!!
2nd Time w/Braces
