got a tiny spring in my archwire
IceBlonde
#1 Post by IceBlonde »
I had to go to my ortho's office last week for an "emergency" (my archwire came unfastened from my back bracket), and my stainy ligs needed changing. He decided to put a tiny coil spring in to help make space for the small tooth to come out from behind my front tooth.
Now my not-so-noticeable ceramic braces are slightly more noticeable thanks to this coil.
I needed to wax it right away because it was rubbing the inside of my poor lip raw; it's a little better now.
On top of that, food gets caught in it like mad :x I could have starred in a zombie movie after spinach pizza!
Anywho, I am wondering if anyone else has had this space-making little spring put in, and how long you had to have it in for.
Thanx!
IceBlonde
badbite
#2 Post by badbite »
I will need one at my next appointment for the same reason. I am not sure how long you'll need yours in for becuase eveyone is different and i am sure it depends on how much room you need to make.
RPE in on Jan 7, 2008
SARPE on Jan 11, 2008 expanded 7 mm
RPE out on May 14, 2008
funshine
#3 Post by funshine »
I had a spring for a little over a month. It's amazing how fast it moves teeth!
markGl
#4 Post by markGl »
had them in for all four months... just now got my bottom ones taken off.. :roll:
lueyfufu
#5 Post by lueyfufu »
My ortho put in two springs like that at my September appointment. He took one out at my appointment yesterday, so it was in for about a month. I still have the other one, so I guess those teeth haven't moved enough yet.
So I guess it just depends on how quickly your teeth move and how much of a space needs to be made (or closed.) :)
Lower braces: 7/1/08
Expander installed: 7/8/08
SARPE: 7/15/08
First adjustment for lowers: 8/5/08
Expander tied: 8/11/08
Upper braces: 8/28/08
Lefort I & BSSO: 1/8/13
