Hi guys,
My upper left canine is has rotated perfectly but its not moving to close the extraction gap. The right side is almost closed! Its been over 12 weeks now and my ortho keeps saying it will move. The space feels the same during flossing, like pre-braces!
My adjustment is tomorrow morning. Can a elastic band move the tooth? I'm bring this up tomorrow and suggestions?
Thanks!!
Canine is not moving
I have just completed my treatment!!
hi,
I had a gaps on both sides between my canine and the tooth next two my front teeth(forgot their names) my left side moved but my right never seem to move to me but my ortho said otherwise. I wore a closing spring on my left side and a spring and an elastic on my right side to help close it. Ask about closing springs and elastics and see what your ortho says. Good luck! Oh and not to scare u but springs hurt but they worked according to my ortho.
