Am I the only one with problems like this ?
Hello everyone! I just got my braces off in November and I have had nothing but trouble ever since. I am at the point that I have to say, even though I wanted a beautiful smile, I regret ever walking into the orthodontist's office. I am now facing two crowns and the possibility of having braces put BACK ON to correct my teeth. I have terrible gaps between my back teeth that are so bad tooth picks and dental floss will not get it out. I have to use larger objects just to remove food from my teeth every single time I eat. I just will not accept that this is the way they are supposed to be. Has anyone else had this problem? Is it just an adult situation? Help !!!
Sorry to hear about your problem, I hope that it can be corrected easily. Did you speak to your orthodontist about your concerns? Sometimes depending on the shape of your teeth and gums there is not much that can be done orthodontically to correct a problem of getting food stuck between them. Are you wearing a retainer?
Russell Mullen, DDS MS
Leesburg, VA
Remember: your orthodontist knows your dental history and orthodontic condition best. I can guide you toward better orthodontic information than if you were left on your own and hopefully in doing so play a small part in your quest to achieve a beautiful, fully functional smile, but you should consider your orthodontist the best source of information.
http://www.mullenortho.com
Leesburg, VA
Yes and Yes. I do wear my retainer, although now I just wear it at night and my next appointment is in December. My bottom retainer is non-removable. I have talked to my orthodontist and I have to say he has an out of this world bed side manner and is a pure joy to talk to and be around. We have always joked and laughed at my visits about things going on in my life. So, when I asked him if these things were normal, he replied, "for anypne else, probably not, but for you... anything is possible!" That was as far as I ever got. I told the x-ray tech that I thought this was one of the biggest mistakes I had ever made, but got nowhere with her either. I just don't know what to do.
Maybe you should take a more direct approach with your orthodontist and tell him that you're really unhappy with your results so far. Maybe he was making a joke (since y'all seem to have a jovial relationship) or maybe your teeth are a unique case. I know several people on here have had to be braced more than once. But perhaps you could schedule an appointment that is just a "counsel" sort of meeting where you tell him your concerns and he tells you his plans of action. It sounds as though y'all have an open line of communication, so hopefully talking this out will make him understand that you're more concerned than perhaps he realizes. And if you still feel like you're not getting through to him after you've made a true attempt to work it out, then maybe a second opinion might help.
Check out my braces story for pics !
Thanks!
Thanks to both of you for your advice. I will try that. AFter all, nothing ventured: nothing gained !! I'll let you know how it goes. My husband will be so glad to know that I am telling someone besides him how much I hate my teeth!! Thanks again !!
