im due for a milk tooth extract in a week
has anyone had one of these? how painful is it and what should I know for aftercare etc
milk tooth extraction?
Primary teeth are typically very easy to have extracted; much easier than wisdom teeth!
Russell Mullen, DDS MS
Leesburg, VA
Remember: your orthodontist knows your dental history and orthodontic condition best. I can guide you toward better orthodontic information than if you were left on your own and hopefully in doing so play a small part in your quest to achieve a beautiful, fully functional smile, but you should consider your orthodontist the best source of information.
http://www.mullenortho.com
Leesburg, VA
