Consult Appointment/Oral Surgeon
eoberhauser
#1 Post by eoberhauser »
Since the shock of being told I'm almost done, I went to my dentist to have a cleaning and have him check out my "peg" lateral that will need some work done to match my new implant for the other lateral. He suggested a porcelain veneer as opposed to bonding. I've done some research on the boards here and it seems like the veneers would be a more permanent and aesthetic solution. I also made a consult appointment with the Oral Surgeon to discuss my implant surgery. I will also be having 3 wisdom teeth removed at the same time. I can't wait to give you guys an update. My appt is 8/14 so I'll have some news then!
Erin
