Is this normal with expanders?
adrienne
#1 Post by adrienne »
Today I woke up and my nose was killing me! I then went to brush my teeth .. and there was this really really small gap between my teeth but it was definetely a gap :shock:
Then I decided to smile in the mirror to see the changes from my 7th turn and my smile was definetely wider which I was happy about .. but then I realised that my nose got wider and I was in absolute shock :( I'm only on my 7th turn and I have 23 more turns to go .. so does that mean that my nose will get bigger and bigger? Cause from what I see .. I'm not too pleased with what I look like now .. :cry:
;ADRIENNE
RPE for one month: 45 turns
quad-helix, lingual arch
ceramic braces for 18 months
braces off!
adrienne
#2 Post by adrienne »
.. anyone?? :?
;ADRIENNE
braces off!
Filip
#3 Post by Filip »
In my case my cheek bones certainly have become more defined, now at the limit of what I think is "attractive"/what I feel comfortable with. Once in a while I think my nose has gotten wider, but since I've long passed the expansion phase, so I can't really tell. And now it's too late to reconsider anyways.
Don't know if that helps.
RPE for 5 months
In: 08-Feb-07 Out: 20-Jul-07
Molar rotator for 2 months
In: 24-Jul-07 Out: 14-Sept-07
Carolinahigh12
#4 Post by Carolinahigh12 »
Well from my experience from when my son had an expander, his nose really didnt change, but he did gain a gap. The dentist wanted his back molars to bite better, and with expansion he gained a gap. The gap went away on its own because the palate tissue filled in and harden ( if that makes since). Basically, it is normal for the gap to appear during expansion because your palate is expanding, but this will have to happen in order for you to correct your mallocculsion (if I spelled that right)
~~~Nicole~~~
adrienne
#5 Post by adrienne »
Yeah well whenever I get a teeeeeny weeeny gap .. it seems to close in the afternoon all by itself 8)
But my nose hurts SO much...it feels like someone just punched me in the face .. pffft. :cry:
;ADRIENNE
braces off!
peach
#6 Post by peach »
Hi Adrienne,
I remember reading on several sites about expanders that they can affect your profile by widening the nose along with your smile. Also, you should expect to have a gap form between your front teeth. Try googling palatal expanders :) .
Brandyleigh35
#7 Post by Brandyleigh35 »
I had surgically assisted rapid palate expansion last year. My nose did get a bit wider. This happens because your maxilla is getting wider and it is attached to your sinuses so they have to expand a bit with the maxilla. I finished out with 9mm of expansion, and my nose was very minimally changed. It won't keep expanding with every turn, but yes, it will probably get a little bit wider.
Brandy
samantha_lou
#8 Post by samantha_lou »
I'm on my second expander, I haven't noticed anything going on with my nose - my smile is definitely getting wider, but my nose seems unchanged. I would definitely mention it to your ortho!
Good luck, hope all is well!
adrienne
#9 Post by adrienne »
Brandyleigh35 wrote:It won't keep expanding with every turn, but yes, it will probably get a little bit wider.
Brandy
Phew that it won't keep expanding with every turn .. I thought I'd end up like a monkey or something after all my 30 turns .. :lol:
;ADRIENNE
braces off!
adrienne
#10 Post by adrienne »
But .. will the gap between my teeth get bigger after each turn??! :?
;ADRIENNE
braces off!
BrandonH
#11 Post by BrandonH »
Well, one week into my RPE and I woke up this morning and I felt like someone sucker punched me in the nose. It's just sore --- very funny.
My mouth and jaw feel like a million bucks, but note hurts and my sinuses are going crazy.
I guess it's working!
