Hey all
just got my sonic brush last week. According to the directions it says to replace head every 6 months. Doesn't that seem a little long to be using the same brush ? Doesn't sound very hygenic to me. They say to clean it with water. Is there a better way to clean the head ?
Ives
Sonic brush question
Braced March 1st 07
I run mine under extemely hot water. You could use hydrogen peroxide, since they put that in toothpaste anyway. Just be sure and rinse it well.
I think 6 months is reasonable with those brushes since the heads are so expensive!
Damon 3s. On 2/15/2006. Off 2/21/2007!
Essix on uppers, Hawley on lowers.
Six months for normal people. Braced people aren't normal (at least in this case). I use mine for my nightly cleanings and can tell a real difference in cleaning in a month's time.
Mike
Mike
But who's counting?
Jaw Surgery June 1, 2009
But who's counting?
Karen - it is funny. I assumed that with braces my brush heads would get shabby quickly, but I am happy to say that has not been the case (oral b sonic). As to the bleach, I see a holistic doctor who recomends disinfecting toothbrushes in a waterd down bleach solution whenever you are sick or feel a bit under the weather. She says that it helps....who knows? I figure after paying her so much money I might as well do what she says
I have an e-series Sonicare toothbrush, the head brush is kind of wear now, it's been 2.5 months. I clean it with water only as I'm the only one who uses it. I brush 2, 3 or 4 times a day but I only use the Sonic at night, during the OTT. I think I will replace the head when it's 4 months old. Yes, brush heads are expensive, but it's well spent money, especially for me with braces
Full Metal Mouth
