will /did a Busy Orth lengthen your treatment time??
I finally made my decision to get my brace but now the next big question is who I should choose. Recently I went to a few local orth and they all have similar cost.
So now my main concern is the length of my treatment. There is one Orth where I pretty much have to book 3 months in advance to see him just for consultation. Now is this a sign of a busy orth and dose that mean I'll have a longer treatment length because of this? Since think he probably he will extends the time between adjustments to meet his busy schedule, is this very possible (they probably might make up some excuse that you have no way to check for clarity like " your gum need more time to adjust " or " you teeth needs some time to heal iteslf" ? Dose anyone have their treatment time lengthen due to this???
W
W
o.. so u telling me the archwire will adjusts itself ?? I thought the archwire can only be adjusted (tighten) by the Orth. So for clarity purposes , lets just say if nothing breaks and the archwire stays in working condition (which I know is not possbile) then I dont really need to visit the orth at all.. I'll just let the arch wire do its magic??
sorry about this.. i'm still a newbie on this subject
Thank you for your all the replies but it really doesn’t answer my question. Very likely I didn't ask it in the correct way or due to my lack of English skill, I must apologize. If an orth extends the time between adjustments (because of his busy schedule) doesn’t it make the whole treatment time longer??? Let say, after 2 weeks my teeth are ready for another tightening or adjustment but my doctor is not.. Don’t my teeth will just sit there (waiting) for the next adjustment??? Waiting =leads to longer treatment time
I know I should ask my orth, wouldn't I run a risk of getting a bias answer since I dont think the doc wants to tell their patient that their treatment time is longer due to their busy schedule.
i'm going to go out and say that yes, it's possible that going to a busy ortho may extend your time in braces. for example, i should be going in this week for my last appt before I get my braces off the following week. However, there were no open times for this week, so I have to keep my braces on longer.
I agree with tatania. It is possible that a busy ortho can make your treatment time take longer. Some people have to wait for a really long time between their consult and their braces placement or longer for their spacers. Also:
Good Luck!
I have self ligating brackets and I have never had an appointment be longer than 6 weeks. My ortho is not very busy as I believe he is fairly new to this office. My treatment has been a bit weird because my lower teeth are way more crooked than my upper teeth so my upper teeth have had to sit around and wait while the lower teeth did something. Still - never more than 6 weeks and sometimes as short as 4 weeks. Also, there was a very short time between my conult, my records apointment, my spacers and my braces installation.Most adjustment timelines are longer than 2 weeks. OK, perhaps at the very end of treatment when the ortho is making last little bits of fine tuning the timeline between appointments might be short like that, but for the bulk of treatment 6 - 8 weeks, 8 - 10 weeks, or 10 - 12 weeks would all be more typical. The shorter times are more the norm for brackets that need ligs. Self-ligating brackets often come with longer times bwteen adjustments.
Good Luck!
Mid Forties!
Mid Forties!
Ya it seems some people have 6 weeks to 10 weeks adjustment gap. I know it really depend on your condition, but it seems quite possible your orth’s schedule effects the length of this gap as well.
Please correct me if I’m wrong.
So let’s say your treatment needs 18 adjustments
Since there is 53 weeks in one year, sooooo :
For a normal orth
18 adjustment x 6 weeks = 108 weeks = 2 years and 2 weeks
For a busy orth
18 adjustment x 10 weeks = 180 weeks = 3 years and 5 months
So as you can see, with a busy orth you are going to be on brace for 1 and half year more !!!!comparing with a normal orth. I dont know about u, but it seem 1.5 years seem like a long time for me. Of course I might exaggerated a little bit with the 10 weeks (probably should be 8 weeks, but 1 year extra is still alot), but you get the point. If an orth have a habit of delaying your adjustment, it will build up quite a lot of your whole treatment time. Again this is just a general estimate (different patient, different doc will have different treatment time..) but it seems it makes some logical senses for a general rules of thumb.
I guess now my question is, is there anyway to prevent this from happening ? maybe some sort of written agreement saying that , adjustments shouldn't be no longer then 10 weeks for certain condition.. etc etc...
For a normal orth
For a busy orth
Well what if your teeth are ready to be moved to the next wire in 4 weeks and your appointment isn't until 6 weeks?What if your appointments were 4 weeks apart, but he only changed wires every second appointment? Would it not have been about the same to go in every 8 weeks then? (Of course, this is neglecting the question, if applicable, of needing to replace ligs)
Here is what I think. After the first few visits your ortho should be pretty good at telling if your teeth are moving quickly or not. They should be able to estimate when the next adjustment is needed. Now once they have determined that, AS LONG AS they have time for appointments and are not purposely pushing them out to 8 weeks REGARDLESS of how fast your teeth are moving then you will have an optimal treatment length.
My ortho never gives me a choice of 4 or 6 weeks appointments. He always tells me when to book my next appointment.
I myself think that the 6 weeks my ortho is giving (currently) is perfect. I can tell right now after 4 weeks that my teeth still needs to settle down just a bit before the next appointment. And I am positive that if I went in after 6 weeks and he thought that I needed to wait another two he would put my appointment in 2 weeks, not in another 6 weeks.
Mid Forties!
Mid Forties!
I dunno, I'm still waiting for my first consultation with him, heh.Out of curiosity, was your apparently very busy doc offering the longest estimate?
It has been a month now (going to need to wait for another month). But I heard he is very good, thats why he is so busy. So during this time, Im just wondering if it is worth it to wait for a good busy orth or just get a decent orth with less scheduled appointment. I'm getting a mix message from all the replies. Some say yes and some say no, and if its is true then its likely I can't proof that with my orth as well
I have absolute confidence in my ortho, and so far every appointment has been either six or eight weeks apart.
It's pretty weird, the first week will be a little uncomfortable and then it feels fine, but then a couple weeks later my teeth feel uncomfortable again, like the treatment just continues without an ortho appointment.
It's a two year process.......
Also keep in mind that just because your teeth moved does not mean you are ready for the next appointment.
After the teeth move the root of the tooth needs time to catch up. If the roots are moved too quickly they decrease in size, and you can start to lose teeth if it is done too quickly or too much at a time.
Just because a gap closes in the first week does not mean the rest of the time is wasted, for your roots are still doing their thing.
Unfortunately orthodontic treatment is not something that can be done quickly. I would be careful of any orthodontist who quotes a super-fast treatment time, as the roots are very important and need time to adjust.
Try to make the best decsion for yourself. Don't worry about time. If he tells you it will take 24 months he should try to have it meet that time period unless your teeth (and not his schedual) requires him to alter your schedual. I know this is a big deciscion for you and it took me several years of research before I made the jump, but don't worry so much. Pick an ortho and go for it. Don't do math in your head your only going to confuse yourself. I have had my braces on for 13 days now and I barely remember I have them most of the time. I want to get them off ASAP, but they really don't bother me anymore.
