| View previous topic :: View next topic |
| Author |
Message |
funshine
Posted: Tue Jun 17, 2008 6:46 pm Post subject: Softest Toothbrush |
I prefer manual toothbrushes. I got a great one from my dentist. It's GUM brand, but I can't find it in stores anywhere.
What's the softest toothbrush you've found? _________________
| Back to top |
Meryaten
Posted: Tue Jun 17, 2008 7:54 pm Post subject: |
| My current brush (brushes actually, as I have one stashed in my office at work too) is a Colgate. It's very soft. |
| Back to top |
funshine
Posted: Thu Jun 19, 2008 5:33 pm Post subject: |
Thanks, Meryaten!
I have a Colgate, too, but it isn't nearly as soft as the GUM brush. Maybe Colgate makes one in extra soft/sensitive (?) I'll have to check it out. _________________
| Back to top |
Meryaten
Posted: Thu Jun 19, 2008 8:37 pm Post subject: |
| Wow. Those must be some soft brushes. Have to say, I am petrified of overbrushing and damaging the enamel or (more likely) the gums. |
| Back to top |
adultbraces
Posted: Sun Jun 22, 2008 10:46 am Post subject: |
Once I came across this colgate brand felt like soft as feathers. The pkg said 'soft' but material was something else, I can't find them again at the stores.
But I found that soaking in a hot water before brushing helps soften the brush extra. Try it. |
| Back to top |
funshine
Posted: Sun Jun 22, 2008 4:14 pm Post subject: |
Soaking is a good idea. Thanks! _________________
| Back to top |
¤sabrina¤
Posted: Mon Jun 23, 2008 5:32 am Post subject: |
i use manual oral b advantage plus brushes and i think they are the softest
i actually find gum brushes are hard!!
i bought one and used it for a week and found it was hurting me and went back to my oral b _________________ my story -- http://www.archwired.com/phpbb2/viewtopic.php?t=25125
February 29 2008 - initial consultation, records and spacers
March 17 2008 - molar bands
March 20 2008 - 2 upper 1st premolar extractions
April 17 2008 - upper jaw braced
April 24 2008 - lower jaw braced
May 1 2009 - primary left central incisor extraction |
| Back to top |
funshine
Posted: Mon Jun 30, 2008 7:52 pm Post subject: |
I'm starting to wonder if it's a child's brush. The head is so small and very compact. _________________
| Back to top |
Lilypad
Posted: Wed Jul 02, 2008 3:26 am Post subject: |
| I got a couple of Gum extra softs from my periodontist and I love them. Been looking around the stores and havent found them yet. |
| Back to top |
funshine
Posted: Thu Jul 03, 2008 10:06 am Post subject: |
That must be what I got - Gum extra softs. I sure wish I could find them in a store. _________________
| Back to top |
¤sabrina¤
Posted: Fri Jul 04, 2008 12:44 pm Post subject: |
would love to try that gum extra soft as well
i bought another gum soft orthodontic brush today to try as they were in stock
one spot in the back is sore, ill see if thats from the cleaning i had this morning or the toothbrush
the ortho brush was soooo much easier to use than a normal
i got a gum end tuft as well
and a colgate kids stage 2 (i use it on the last molars and behind front teeth) _________________ my story -- http://www.archwired.com/phpbb2/viewtopic.php?t=25125
| Back to top |
funshine
Posted: Mon Jul 14, 2008 8:19 pm Post subject: |
sabrina - where'd you find the Gum soft ortho brush? _________________
| Back to top |
¤sabrina¤
Posted: Tue Jul 15, 2008 6:31 pm Post subject: |
funshine, i live in Trinidad in the caribbean, found it in a pharmacy
that reminds me i perfer ortho brushes to regular, i need to go buy all they have in stock, saw less than 10 on the shelf
its the regular soft one, not extra soft, works out to about US$2 for one brush
the sore spots that it caused cleared up in a couple days _________________ my story -- http://www.archwired.com/phpbb2/viewtopic.php?t=25125
| Back to top |
funshine
Posted: Wed Jul 16, 2008 8:51 pm Post subject: |
Okay...I think I've found the absolute best brush...ever.
I found it at Target and the brand name is "Preserve". The brush is oh-so-soft and the handle is angled perfectly to reach everywhere. I absolutely love it. My next trip to Target I'm stocking up! _________________
| Back to top |
¤sabrina¤
Posted: Thu Jul 17, 2008 4:34 am Post subject: |
lol is it an ortho brush?
i went an bought all the gum ortho softs yesterday only got 6 though, the girl told me she will check and see if they have more to put out
it cuts down my brushing the braces time alot _________________ my story -- http://www.archwired.com/phpbb2/viewtopic.php?t=25125
| Back to top |
