My Damon Clear Story!
Re: My Damon Clear Story!
Looking good and fast progress too. I wish my teeth moved as fast as yours!
- aspiromusings
what movement! them bottoms especially look amazing, you are going to have a spectacular result by the end27braces88 wrote:3 Month update
Blog - http://aspiroisbraced.blogspot.com/
Top Braces on 20th March 2015
Bottom braces on 28th August 2015
Top premolars extracted 25th April 2015
Debraced 15th December 2017
Thanks guys. Just over four months in now and things are starting to slow down a bit. Getting my first rectangular wire next week so hopefully everything will start falling into place then.
Already counting down the days until they're off. 8 months to go!
So today marks 5 months in braces. Original sentence was 12 months so nearly half way there. Getting a clean next week which I can't wait for as I think braces wearing is taking it's toll.
Here are some photos:
It must be working then!27braces88 wrote:So rectangular wires hurt!
What fabulous progress, are you pleased with how its coming along?
Yeah, it's getting there. My right central incisor is now angled in and my midline is way off but hopefully it'll all work out over the next few months.NeilH wrote:What fabulous progress, are you pleased with how its coming along?
Definitely much happier with my teeth now than I was 6 months ago
Your teeth looks great by the way, I bet you're super happy!
Just caught up with your journey so far. You are right our teeth do look similar. Your progress has been fantastic. Your teeth already look gorgeous. Hopefully mine will follow suit.
Forgot to ask did you have any teeth pulled or IPR (filing) between teeth to make space or just braces?
No, no extractions. They haven't said anything about IPR yet either, although i think i might need some on my bottom teeth as they're a lot wider at the top than at the bottom so I'm getting a few gaps.Lovelyteeth wrote:Forgot to ask did you have any teeth pulled or IPR (filing) between teeth to make space or just braces?
I'm starting to notice a couple of triangles already too. Grrrrrr.
Today marks a whole 6 months in braces. Which is also (hopefully) my half way point.
Dramatic changes in how my teeth look are a thing of the past and I can see very little difference between month 5 and month 6. I am now officially bored of having braces.
I had a clean a few weeks ago, the hygienist said that she doubts I'll make it to 12 months so fingers crossed the come off a bit sooner.
This is my progress so far. Looking back now I can't believe I lived with teeth like this for so long.
Hi, they are looking really good, you are going to have a super smile when you are finished. What is your ortho working on now? I guess you are the stage when they are making the bigger movements and aligning your bite?
