Acid on teeth
noorcas
Acid on teeth
#1 Postby noorcas » Wed Aug 24, 2016 8:43 am
Hi,
a month ago I finished having braces and received a clear retainer to use constantly. I use it only during the night.
In the morning when I remove the retainer, there is a very acidic taste on my teeth, from the saliva that has been trapped the whole night between the teeth and the retainer.
I have read that this can very easily cause tooth decay. I also read that brushing the teeth immediately after such exposure to acid can effectively damage and even remove the enamel.
I do not know what to do. I have my next orthodontist appointment in a month. There is very little information on the internet about the effects of acid due to retainer wear.
So far, the only solution i see is to wear the retainer during the day (at least 8 hours), so i can remove it from time to time and rinse my teeth.
Does anyone has any experience with this? I am really interested to know more.
Thank you.
breysanchez
Re: Acid on teeth
#2 Postby breysanchez » Wed Aug 24, 2016 7:52 pm
Bump
I'm in the same boat. :shock:
Age: 1990 Kid
Sex: Female
Braces: Damon Clear (top) Metal (bottom)
Sentence: 24-30 months
oldfart
Re: Acid on teeth
#3 Postby oldfart » Thu Aug 25, 2016 5:38 am
One of the many reasons I switched to a Hawley retainer. My essix was a bacteria magnet.
lambchop
Re: Acid on teeth
#4 Postby lambchop » Fri Aug 26, 2016 1:09 am
As long as you've thoroughly brushed and flossed, shouldn't the same spit that normally accumulates on your teeth during the night without a retainer be the same crap that accumulates inside your retainer during the same time frame? I'm only 3 months out of braces after nearly 5 years, but it seems like mouth chemistry is mouth chemistry...either you're prone to stuff or you're not. I will say that I want to flush my mouth out with fresh water in the morning after taking out my Essix, but it doesn't seem too much worse than when my braces were in. I swish, eat breakfast, then brush soon after...so far, so good!
SingleJawMelb
Re: Acid on teeth
#5 Postby SingleJawMelb » Sun Oct 09, 2016 7:08 am
Isn't Invasalign the same?
turtle
Re: Acid on teeth
#6 Postby turtle » Fri Oct 13, 2017 8:43 pm
I have the same issue with my clear retainer. I am especially worried since I have acid reflux. I plan to ask my orthodontist about it the next time I go in for a check up.
BlondeCam
Re: Acid on teeth
#7 Postby BlondeCam » Sat Oct 21, 2017 6:38 am
lambchop wrote:As long as you've thoroughly brushed and flossed, shouldn't the same spit that normally accumulates on your teeth during the night without a retainer be the same crap that accumulates inside your retainer during the same time frame? I'm only 3 months out of braces after nearly 5 years, but it seems like mouth chemistry is mouth chemistry...either you're prone to stuff or you're not. I will say that I want to flush my mouth out with fresh water in the morning after taking out my Essix, but it doesn't seem too much worse than when my braces were in. I swish, eat breakfast, then brush soon after...so far, so good!
This is my basic routine as well. I haven't noticed a particularly acidic taste. Also I only put them in after brushing and keep them in a glass with denture cleaner to kill bacteria when I'm not wearing.
Return to “The Naked Tooth (Retainers and Life After Braces)”
Who is online
Users browsing this forum: No registered users and 1 guest
