taking pictures for your blog
I have seen loads of people on here with really good pictures for their blogs. How do you do it?! I find it hard to take it from the angle each time which makes it difficult to compare shots and see if there is actually any progress.
Re: taking pictures for your blog
Hey there, i find it takes practice, i use a webcam because its easier than using a camera with a flash. Plus you dont have to hold it. I also use the images i recieved from my orthodontist, they are the best ones really.
