Teeth grinding
Teeth grinding
My dentist recommended I get braces (again) to help with teeth grinding and TMJ issues. I’m in my late 20s in Ireland. Had braces before and it was a good experience teeth shifted and over the past several yeaes I’ve had awful headaches. She thinks braces will help. Apparently my second molars ?? are too high now and I have a crossbite on several teeth. Will braces help this?
Re: Teeth grinding
There is a dentist who posts here, and who might be able to answer your question; I am certainly not qualified to venture a guess. Have you consulted with an orthodontist? Best of luck to you.
Re: Teeth grinding
hi Duallydani. From your post it sounds like you have some issues which orthodontics can address and correct. TMJ issues are frequently multi-factorial. Orthodontics may improve or possibly even resolve your TMJ issues but I would reluctant to refer a patient for orthodontics on the presumption that the orthodontic therapy would resolve the TMY issues.
