It is currently Tue May 21, 2013 6:09 pm
Post new topic Reply to topic  [ 2 posts ]
Author Message
 Post subject: Wire springs
PostPosted: Sat Jan 12, 2008 6:16 pm
Offline
Hey everyone!
My 12 year old daughter has been in braces for about 10 months now. This past Monday, our Orthodontist put yhese wire springs on both sides of her mouth. She is in a tremendous about of pain, can hardly open her mouth, cannot eat, and has bad sores on both sides. She says the wax they gave her did not stick, although I don't think she is trying hard enough to put it on! Any suggestions?
Thanks in advance!
Therese
Top
 Profile
 Post subject:
PostPosted: Sun Jan 13, 2008 2:02 pm
Offline
The tricks to wax are to use enough, and sometimes it really helps to dab the hardware dry before applying it.
Your daughter should also be especially diligent to stay properly hydrated, as the mouth will tend to respond more poorly to new hardware if its tissues are at all dried out.
Meanwhile, the sores will hurt less if acidic foods and beverages are minimised or avoided. Chewing a Tums (or similar antacid) can also sometimes provide relief from the pain for the same reason.
Hope this helps.
Top
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
